Any one help with BIG problems on DS?????
Old Oct 24, 2003 | 10:23 PM
bunnie's Avatar
Default Any one help with BIG problems on DS?????
I have a 2000 ds all stock the needle is on the 2nd clip up from the bottom and the air/fuel screw is 2-3 turns out and I need to know why it is backfiring through the carb wont idle right pops and mainly the header pipes are glowing cherry red. I only run 93 octane and the top end was just rebuilt for burnt exhaust valves. any help or advice would be most helpful
thanks
Old Oct 24, 2003 | 10:37 PM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
No dought your lean but have you checked for air leaks in the carb boot or intake. If your that lean thats where id start then go after the carb!!!
Old Oct 25, 2003 | 10:37 AM
BajaIowa's Avatar
Even though the head was just rebuilt, I have heard of backfiring because the intake valves are too tight. Might be worth a check.
Justin
Old Oct 26, 2003 | 12:05 PM
rigomex's Avatar
[img]i/expressions/face-icon-small-sad.gif[/img] My friends ds has dual carbs and he cleaned out the carb had the same problems you mention. He missed cleaning the pilot jet. I told him to try that he removed pilot jet and found tiny pieces of dirt he blew it out with high pressure from power tank and magically it ran perfect.
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
