Banshee Idleing Problems
Old Oct 28, 2003 | 09:29 PM
simp's Avatar
Default Banshee Idleing Problems
I got a 04 Banshee and just got the Tors kit installed with the idle screws, which are turned all the way in, and it still won't idle. I turned the adjusting bolts on top of the carbs out to try to bring the slides up a little bit but when i rode it the throttle hung and about killed me. Has anybody had the same problems if so what did you do to make it idle. Thanx
04 Banshee
FMF SST's
K&N
V-Force reeds
boost blottle
Tors Kit
Old Oct 29, 2003 | 03:17 AM
Trxoutlawz's Avatar
First of all, check to see if your idle screws are acually touching the slides. ( Did you shave down the spot for the screws before your drilled and tapped them...
Old Oct 29, 2003 | 11:01 AM
sAyIt_fmf's Avatar
I agree....before I tapped the holes for the idle screws....I had to shave down the area on the carbs....
Old Oct 29, 2003 | 11:24 AM
Hiram's Avatar
Also make sure the slides are put back in with the slanted cut towards the air filter, if it in wrong it wont allow air to enter at idle and this happens when you put the left slide in the right and the right in the left, be care and double check it.
Old Oct 29, 2003 | 11:36 AM
BlackWidow's Avatar
Hiram has a good point there. The other thing that can happen is that the locating screw for the slide can back out (off the top of my head I don't remember if this is the idle speed screw or not). My brother had this happen to him and it made some goofy things happen!!!!!
From what I have seen and heard... the TORS kits are notorious for sticking... I don't have a solution for you right now but they seem to be worse in humid and cold weather in our area.
Hope this helps
Old Oct 29, 2003 | 08:49 PM
simp's Avatar
Thanx
04 Banshee
FMF SST's
K&N
V-force reeds
Boost Bottle
Tors Kit
KimSJoh
14
Jul 18, 2015 07:20 PM
ranvette
Jul 12, 2015 06:34 AM
Jul 7, 2015 11:00 PM
MNatv89
Jul 7, 2015 11:36 AM
