sheared decompression pin
Old Nov 3, 2003 | 11:33 PM
ccgrady's Avatar
Default sheared decompression pin
i have a 686 with a stage 2 cam and i couldnt figure out why it had a hard time turning over. i took it apart and the decompression pin was sheard off. I called hotcams and it is a newer style cam and they had no idea why this happened. Please if you have any idea please let me know.
Old Nov 3, 2003 | 11:41 PM
BigScary's Avatar
well that is probably what is wrong with mine then!
I have been having the same problems you were having.....I read your other posts..........
Now what?
get it fixed and send em a bill?
or don't bother and take the bill up the @ss?
Old Nov 3, 2003 | 11:55 PM
ccgrady's Avatar
i order another pin and will put it in this weekend. i am worried that whatever is wrong will do the same to this one. maybe it was installed wrong but i really dont think so. hopefully someone knows so i can fix it and this wont happen again.
Old Nov 4, 2003 | 01:33 AM
ccgrady's Avatar
someone has to have a idea on what happen.
Old Nov 4, 2003 | 08:59 AM
garyc660R's Avatar
When I installed my pin into the Hotcam the hole was a tad too small....restricting the pin from smooth movement. I guarantee this would have led too premature failure if I had not cleaned up the burrs inside the decompressioon pin hole of the Hotcam. It was no big deal....I used a flathead screwdriver that was a snug fit in the hole and twisted it a bit...the pin worked flawless after that.
Old Nov 4, 2003 | 09:07 AM
sixsixT's Avatar
When you put it together make sure the pin retracts when you turn the actuator, if the actuator is put in 180 degrees out the pin will not retact and wouldn't last very long and the engine won't run to good either untill the pin fails.
Old Nov 6, 2003 | 11:29 PM
ccgrady's Avatar
that was the problem. you could feel the new one drag or bind in the hole. it was cleaned a little with a drill bit and now its starts like it did new.
FISHER1648
Dec 4, 2004 06:18 PM
RepTaR660r
Feb 10, 2003 10:43 PM
AdamsBadDS650
Feb 10, 2003 07:23 PM
markkh
Jun 5, 2000 04:06 PM
