Warrior Headpipe Help
Old Nov 10, 2003 | 12:54 PM
warrior68man's Avatar
Default Warrior Headpipe Help
I was taking my exhaust off (headpipe and silencer) to paint them with that 500degree engine paint
While taking the headpipe off, I snapped the nut and part of the bolt stuck into the nut off. I figured no big deal..cuz i put it back on and there was barely any leak....so I painthem them, put it on...was tightening down the other bolt..and the nut came right off the bolt and started spining freely....
So basicly, I had to bolt-threads stuck in the exhaust manifold where the headpipe connects....and ideas on how to get these out?
Thanks
BTW, it looks sweet painted lol.
Old Nov 10, 2003 | 01:27 PM
jumpingjack's Avatar
If you still have some of the stud left, you can get a stud removal tool to remove the studs and then install new ones. I would soak them with WD40 or liquid wrench a few times and let it soak in for at least 24 hours before trying to turn them out. If the studs break off in the head, you will have a lot more trouble - you will then need to use an EZ-out (bolt remover) and a helicoil.
Old Nov 11, 2003 | 02:35 PM
kawasaki78man's Avatar
hi justin i forget how to take it out hmm just use ur might and rip it out
Old Nov 11, 2003 | 03:07 PM
You can get metric stud pullers from Northern Tool or All-Tool (http://www.all-tool.com/BY_MASTER_CA...pullers_16.htm)
Old Nov 11, 2003 | 04:34 PM
KILLERCUDA's Avatar
Can't help with the head pipe bolt prob. But I can tell ya one thing that 500 Degree Paint will not be enough not even on a stock machine I was over 500 degrees with a stock machine. Go 1200.
Reactant
Mar 30, 2022 02:08 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
Reactant
Jul 27, 2015 07:45 PM
