help !!coolant leak on 400 explorer
Old Nov 17, 2003 | 03:06 PM
machman's Avatar
Default help !!coolant leak on 400 explorer
My 400 is leaking coolant out of a tiny hole at the bottom front of the motor, it looks like the bleed hole on a chevy water pump. The fan also stopped working. Is the water pump in there? It dos not look like any part can be removed from the area around the hole. Any help will be appreciated.
Old Nov 17, 2003 | 05:02 PM
Snownut's Avatar
You are in deep doo doo.. It sounds like water pump time. Its time consuming and you will need a special socket from Polaris, but its not too bad of job...
Old Nov 17, 2003 | 10:15 PM
quadwrench's Avatar
The "special" socket can be fabbed from a piece of pipe and a grinder, years ago thats how I did my first one, until I got a milling machine and built a "professional" looking one in my spare time. For all practical purposes, you only need 2 of the lugs. I've been into several that looked like people have used hammers and punches - taking a chance of boogering things up. Just remember the nut is left hand threads and it will come off a whole lot easier.
Make sure you check for slop in the balance shaft - could be the cause of the seal failure.
Old Nov 18, 2003 | 07:17 AM
upnort's Avatar
Took my 500 to the dealer, had heard about bending shaft while removing and how have to disassemble the engine if do, cost about 80$.
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
Oct 9, 2015 02:09 PM
wrencher82
Sep 24, 2015 03:39 PM
Kenidah
Sep 7, 2015 07:50 PM
