carb cleaning
Old Nov 23, 2003 | 09:32 PM
Beefy400's Avatar
Default carb cleaning
i just bought a 300 4x4 its like brand new so like i figured it was sitting for a while so i am debating on cleaning the carb can someone give me some help on cleaning the carb.
Old Nov 23, 2003 | 10:55 PM
BSA's Avatar
BSA
The simple way:
1. Drain the float bowl and gas tank of all gas. Put the old gas in your truck..
2. Spray the carb inside and out with carb cleaner, without taking the carb apart. You can direct the spray at the visible jets and into the empty carb bowl.
3. Refill the tank with fresh brand name gas (Porsche recommends Chevron) with supplemental fuel line cleaner (Techron).
Old Nov 24, 2003 | 01:55 PM
Beefy400's Avatar
thanks alot bsa i thought i was going to havta take the carb off to clean it so i thought it was going to be hard that makes me happy now that i havta do less work thanks.
Old Nov 24, 2003 | 02:27 PM
BSA's Avatar
BSA
Just make sure you use carb cleaner and not something like WD40.
Old Nov 25, 2003 | 10:12 AM
GreatCanadian's Avatar
Why not WD40.....i was considering using it.
Old Nov 25, 2003 | 12:54 PM
BSA's Avatar
BSA
WD40 is a very light lubricant. The carb needs a strong solvent to cut the varnish residue left by gasoline. Carb cleaner is a solvent and does a much better job cleaning carbs compared to WD40. Also, carb cleaner evapaporates quickly.
Old Nov 26, 2003 | 08:40 AM
Thanks....i won't be using WD40.
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
tweeder
Jul 5, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
