Need Exhaust Advice!! Foreman 450 Utility/Hunting Use
Old Nov 30, 2003 | 05:31 PM
bluduk15's Avatar
Default Need Exhaust Advice!! Foreman 450 Utility/Hunting Use
My exhaust is rusted and needs to be replaced.
What exhaust should I get that offers performance, corrosion resistance and dampens sound?
Also, what about replacement shocks?
THanks alot.
bd
Old Nov 30, 2003 | 11:43 PM
bluduk15's Avatar
Anyone?
Thanks,
bd
Old Dec 1, 2003 | 01:06 AM
95wolv's Avatar
DG makes the Brute series, a direct replacement for stock,same sound and power output as stock,made of steel like stock. For replacement shocks that are cheap and better than stock,try Progressive Suspension,they carry some nice aftermarket shocks for several models.
Old Dec 1, 2003 | 12:42 PM
action450s's Avatar
I'll be putting on a Supertrap IDS2 soon, mine rusted as well, factory exhaust is way too expensive!!!
Old Dec 1, 2003 | 11:45 PM
SlapNutts's Avatar
I just recently put a IDS 2 on my Foreman 450 '03... I hunt on it but with all of the plates in it, it is pretty loud. Its not bad for cruising but if you wrap down on it you'll hear it. The performance increase is unbelievable. It says that if you take some of the plates out, it'll give you more backpressure, which will give you more torque and a quieter sound. I haven't got around to trying that. You'll like it though.
Valder
Nov 28, 2020 07:38 AM
fordfaithful21
Dec 7, 2015 05:52 PM
Bonzhonda300ex
Sep 17, 2015 10:44 AM
toonces
Sep 5, 2015 01:14 PM
antiguogrumete
Sep 5, 2015 03:41 AM
