03 warrior has probs!
Old Dec 8, 2003 | 07:01 PM
chrisz250's Avatar
Default 03 warrior has probs!
i bought my warrior in sept... and about a month later i here this pingin rattling sound when i rev it or in low rpms... it sounds awful. does ne of u kno what to do... i rele need help!!!
Old Dec 8, 2003 | 07:13 PM
KILLERCUDA's Avatar
Theres a few things
1) Have you changed the fuel octane?
2) The valves may need adjusting
3) Any mods may have caused jetting changes
4) Warriors have noisy valves to begin with
Old Dec 9, 2003 | 05:41 PM
Recon2001's Avatar
Killercuda, what jets do you run in that thing? How fast is it now?
Old Dec 9, 2003 | 09:13 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i kinda have that prob too but it aint been serviced in a while [img]i/expressions/face-icon-small-sad.gif[/img] gonna take it in a few days
Old Dec 9, 2003 | 10:11 PM
yaaaaaa's Avatar
yep check your valves, simplest job there is. take off your gas tank then theres a valve in the font and back of the engine. take the covers off and wiggle it and if it moves quiete abit, then they are out of adjustment, loosen the bolt on top and then turn the screw in untill you can barely wiggle the rocker arm. same thing for booth sides. Very simple. Not the way the book says but your not going to mess anyting up. Thats the way some of the pros do it when they are in a hurry and dont have time to mess with the feeler guages.
Old Dec 9, 2003 | 11:14 PM
warrior68man's Avatar
It's either they need adjusted or the nut fell off the top of a valve and has yet to catch in the motor.
Probably just needs adjusted since it appears your still riding...but man...if there is no nut on the top of either valve, start tearing down your motor and empty your oil....it fell off in the engine...and I had just assumed there was never a nut on there in the first place.....went riding....BAM! snapped the sprocket off the camshaft and jammed the timing sprocket........didn't cost that much to fix...but boy...a big wait.
Old Dec 9, 2003 | 11:16 PM
btw I adjusted mine to the specs with a feeler gauge and it was wrong and didn't run right...so I messed with them and expiremented and got them fine now.
Old Dec 10, 2003 | 09:41 PM
chrisz250's Avatar
thanks guys
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
BigCam
Sep 16, 2015 01:53 AM
toonces
Aug 5, 2015 05:55 PM
