Eiger '02 auto cannot get out of reverse
Old Dec 10, 2003 | 10:28 PM
neumy's Avatar
Default Eiger '02 auto cannot get out of reverse
Any ideas on this one? I cannot get it out of reverse not into neutral or hi/low range?
Old Dec 11, 2003 | 06:49 AM
adamant's Avatar
take the shift linkage off at the motor and try to shift it at the motor ...it could be that your hand shifter linkage is bent...
ant
Old Dec 14, 2003 | 08:45 PM
adamant's Avatar
how did you make out?
Old Dec 21, 2003 | 08:14 AM
neumy's Avatar
Finally up and running! The shifting assembly has two parts, shifting lever and cam type connector to the transmission cable. Suzuki only sells this as a complete unit ($385 thanks alot Suzuki). The two parts are joined by a shear pin (about 1 1/2" long) that keeps them engaged. That pin did its job and broke. A local small engine repair shop guru figured it out in 5 min, taped the broken pin together and cut me another from a bolt (it had a taper to it also) for $30. Guess who is at the top of my shopping list for Xmas. [img]i/expressions/face-icon-small-smile.gif[/img]
lonerider856
Oct 13, 2023 03:45 PM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Clint Russell
Sep 25, 2015 03:20 PM
poutlaw525
Sep 9, 2015 03:19 AM
