My quad dies
Old Dec 14, 2003 | 05:08 PM
manual's Avatar
Default My quad dies
Well right now my batterys dead, so me and my friend decided to try to push start my 300ex, so we would have it going and it would start and i would give it gas and it wouldnt increase or decrease in speed, and than i put my clutch in and it would just die. Does anyone have any clue what a problem is with it?
Old Dec 15, 2003 | 12:42 AM
manual's Avatar
any ideas?
Old Dec 15, 2003 | 01:04 AM
440EX026's Avatar
Well you dont have enough info to diagnose it over the net yet but try this.
A gas engine has some basic things that you can check to eliminate potential problems and then reduce them till you find the problem.
Is it getting gas? Spark? air into the carb or is the filter dirty? Without these three things it wount start or run right etc.
hope this helps get you started and maybe even running [img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 15, 2003 | 01:29 AM
manual's Avatar
Well im pretty sure it is getting gas, but im wondering if the needles is stuck out of position which causes the throttle not to respond, which i will check out when i decide not to be as lazy. I also am gonna check the spark plug. I also think i had bad gas, because we put some into my friends DB, and it stopped it from working. So im going to drain it sometime this week, and replace the gas.
Old Dec 15, 2003 | 04:49 AM
NiceFast300ex's Avatar
What did your battery go dead from? They are a little bitchy to bumstart cold, try using the choke and using, that acclerator pump, just hit the gas a few times as if to prime it and pop the cluctch and she should start. If is doesn't work you are having wiring problems it sounds like. I would try getting a new battery and seeing if that fixes it.
Have you tried charging it? Does you battery getting power to your starter, is it going buzzzzzzzzzzzzzzzzzzz and not turrning over.
I will check back here tommrow.
NO WING NO PRAYER
Old Dec 15, 2003 | 10:30 AM
manual's Avatar
Well the battery is a old battery(from 1994), and while i was charging it, i ended up forgeting about it once, so i overcharged and acid leaked.
Old Dec 15, 2003 | 11:38 AM
kwackermann's Avatar
Yes- classic symptoms of a dirty carburetor..........
Old Dec 16, 2003 | 12:04 PM
action450s's Avatar
Drain and change gas from tank lines and carb. Carb probably needs to be cleaned too. Clean or replace air filter, change the sparkplug, should really have the valve lash adjusted too, while your at it change the oil and get a new battery.
basically just a really good tune up.
Frisky2050
Apr 9, 2020 11:19 AM
Reactant
Jul 16, 2015 10:29 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
Robbbb55
Jul 8, 2015 02:11 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
