Clear Tube from Carb to Airbox
Old Dec 15, 2003 | 09:23 PM
outlaw105's Avatar
Default Clear Tube from Carb to Airbox
This sounds like a stupid question but when I install a carb mount filter what do I do with the clear tube that comes from the carb to the aibox.
Old Dec 16, 2003 | 12:39 AM
ironrod's Avatar
Put a breather filter on it. K&N. You'll also need one for the crank tube.
Old Dec 16, 2003 | 09:22 AM
outlaw105's Avatar
ironrod, thanks for the info..... by doing this , will it affect the slider in the carb?
Old Dec 16, 2003 | 12:05 PM
ironrod's Avatar
I cant see how it would - all your doing is putting a filter on it where it would normally terminate in the airbox. Im confused.
Old Dec 16, 2003 | 04:26 PM
AZDUNNER's Avatar
When I orginally installed my carb mount filter I installed a small K&N type filter on the end of both lines.
I found out after some research that the clear tube is a vaccume line. The carb needs this vaccume as reference to help open the slide.
One of the Forum members helped me out with an adaptor he made.
Contact: Glenn Breem, 4948 Erin Lane Melbourne, FL 32940
aka - gaskett@cfl.rr.com)
The adaptor allows you to re-connect the vaccume line. After installing Glenn's adaptor I noticed a improvement in throttle response.
Old Dec 16, 2003 | 11:59 PM
outlaw105's Avatar
thanks azdunne.... factory it hooks in behind the air filter where i would think some kind of vacuum is present..it must need that to operate correctly or it would not have came that way from the factory .. i'll try it without ,and then i'll drill a hole inthe end of my carb mount filter and snap the tube into it with 2 90 deg fittings and see how i like that... any guys out there with fast bikes please put your 2 cents in on this subject.........thanks.....
Old Dec 17, 2003 | 11:02 AM
TrickyP's Avatar
Ya Glen came up with a sweet mod for the carb mount. I have pics of it. I can't figure out how to post them on here. what's you Email address I will send them to you
slowgsxr97
Mar 18, 2022 03:40 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
ghost civic
Jul 20, 2015 12:36 PM
Reactant
Jul 16, 2015 10:29 PM
