450es Reverse button delete????
Old Dec 15, 2003 | 10:44 PM
Lightfoot's Avatar
Default 450es Reverse button delete????
Can anyone tell me how to bypass having to push down the red button to get in reverse ? It looks like there is also some kind of switch there??? 2004 450es Thanks
Old Dec 16, 2003 | 11:45 AM
action450s's Avatar
Its not a switch, its cable operated. When you push the button down, you put a pin through a lever that is then pulled with the brake handle for the reverse safety thing. The cable operates the unit inside the motor.
To properly disable this, you would have to get inside the motor. Easiest way I can think of is to tape or tie the red button so that its always down.
This way you would only have to have the brake held to go to reverse (which is a life saver of the gearbox).
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
r1pilot83
Sep 27, 2015 07:38 PM
kbazzy
Sep 26, 2015 11:26 AM
95scramblerruben1033
Sep 23, 2015 06:29 PM
