Needle settings
Old Dec 16, 2003 | 12:16 AM
Sanman66's Avatar
Default Needle settings
170mj/42pj I'm running rich, So I assume you would want to move it down right? Where do some of the other 416's run there needles at?
Old Dec 16, 2003 | 12:32 AM
blue250r's Avatar
Yes
Move the clip up the needle which will move the needle further into the jet therefore less fuel
Not sure about a set up for a 416 as i dont have one but it Depends on lots of variables, pipe ,air intake, altitude,ect
try it one notch at a time and check your plug .
Before you start makes sure everything is ok ie clean air filter no collapsed boots on the intake or leaky ones for that matter.
also if it is to rich even at full throttle it will need another jet, needle does nothing much after 3/4
Hope this helps
Old Dec 16, 2003 | 03:32 AM
oz_400ex's Avatar
I have a 416 ,high comp piston ,stage 2 web cam and run a 165 main jet.You should probably lower you main jet size as well...
Old Dec 16, 2003 | 04:36 PM
cals400ex's Avatar
you run dynojets or keihins??
Old Dec 17, 2003 | 12:25 AM
Sanman66's Avatar
keihins..
Old Dec 17, 2003 | 11:56 PM
TractorPacker's Avatar
Do you have a balloon?
Try going to a 40 pilot. I had a 42 in mine and couldn't get it right so I went back to a 40.
Old Dec 18, 2003 | 10:32 PM
Sanman66's Avatar
I do not have a choke on it. So if I switched the 42 pj to a 40 would it make it harder to start?
Old Dec 19, 2003 | 02:13 PM
cals400ex's Avatar
i am running an 11 compression 406, stage 2, x-6, filter, etc. and i am using a 158 main (airbox lid is on) 42 pilot 2 turns out on fuel skrew, and clip is in the 4th position on the needle. you say your running rich?? well, you could be rich with your pilot/fuel skrew, your needle, or your main. you can do a plug chop at idle, at 1/2 throttle, and at full throttle to see where your running rich at. i also say your too rich on your main. you won't be rich enough on the main for it to run like crap though, you just won't have quite the top end like it has potential for. how do you know your running rich?? is the plug really black?? where is your needle set at now??
Old Dec 21, 2003 | 01:09 AM
Sanman66's Avatar
I got it fixed. It runs like a stipped butt ape... [img]i/expressions/face-icon-small-happy.gif[/img]
speedbuff
13
Nov 11, 2020 10:16 AM
Dammar
Apr 20, 2016 06:03 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
Nosniborpapa
Sep 12, 2015 05:54 PM
Hw00d
Sep 10, 2015 08:53 AM
