Error Message on POD of 700
Old Dec 22, 2003 | 12:36 PM
PatsPolarisPage's Avatar
Default Error Message on POD of 700
Was out riding 2 night ago and was in high gear, looked down at the instument cluster and there was a big E where H was suppose to be. It says E in every gear except low (L).
Looked in the owner's manual and it says this happens when the gear selector is between gears, well thats not the case. Also says transmission switch may need repair.
Has anyone had this problem?? Comments???
Thanks guys,
PAT
Old Oct 8, 2006 | 06:47 PM
SAshton's Avatar
Smae bike with same problem? What was it? The Rotary Switch/Sensor on the tranny???
Old Oct 9, 2006 | 12:52 AM
Yes, it was the Rotary Switch/Sensor on the tranny. It was getting water in there. I took it apart and cleaned it out then epoxied it back together.
I still get and "E" in reverse and neutral, but not in Low or High, so the AWD works. When I was getting an "E", the AWD would not engage, so plowing snow was really hard. In reverse, I just have to hit the Override button and it goes into AWD.[img]i/expressions/face-icon-small-happy.gif[/img]
It doesn't bother me enough now to replace it, but if I was still getting the "E" in low or high, I would.
What positions are you getting the "E"?
Old Oct 9, 2006 | 08:47 AM
SAshton's Avatar
Error in High and Low. They are around 60.00 I think so I might replace it.
Old Oct 9, 2006 | 12:24 PM
Kerbbirds's Avatar
Have an 03-700 had to replace mine also, no problems since.
Old Oct 9, 2006 | 05:53 PM
SAshton's Avatar
Kerbirds did you have to put spacers running 26' tires on stock wheels?
Old Oct 10, 2006 | 08:19 AM
Kerbbirds's Avatar
Yes, put a 3/8 washer behind front wheels to clear the tie rod ends, you can also flip the tie rods over, then they will clear.
Old Oct 10, 2006 | 06:31 PM
SAshton's Avatar
A Washer It makes sense but is it ok to do that. A washer to hold all the weight against.
Jeff Roper
Feb 1, 2022 11:48 AM
Jeff Roper
Sep 21, 2015 02:11 PM
patrick.oc123
Sep 16, 2015 03:45 AM
patrick.oc123
Sep 15, 2015 02:45 PM
