can a warn 1700lb winch work on a recon??
Old Jan 3, 2004 | 10:02 PM
hondarulesinnc's Avatar
Default can a warn 1700lb winch work on a recon??
has anyone ever put a warn 1700lb utility winch on a four wheeler cause i got one for Christmas and was wandering if it would work well enough on my recon 250 because if it is pulling 1700 lbs it is drawing 245 amps so i was wondering if my recon made enough power to use this winch. i was also wondering the same things about the winch on my brothers ac 250. so please help me out if you can thanks.
Old Mar 4, 2004 | 08:36 PM
tack's Avatar
I don't know about the mounting, but I wouldn't trust that winch. I've been through 3 in the last month. The problem is the rotary switch. It will short out and cook your battery. I put a Superwinch circuit breaker ($6.00 dollars ) and I put a heavy duty switch from an A2000 winch. This helped a lot. Also, beware of the freespool lever. If it is not fully engaged the winch will break. Good luck.
hugemoth
Jul 20, 2020 03:28 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
MNatv89
Jul 7, 2015 11:36 AM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
