stock rims on prairie
Old Jan 4, 2004 | 07:48 PM
PrairieDeerHunter's Avatar
Default stock rims on prairie
Just wondering if I will notice any performance diff. on a P700 with c-series vs. stock rims as far as power loss due to the weight diff. I think it will be negligable but am trying to keep as much power as poss. with my 26" tires. I believe the diff. is around 10 lbs. total
Old Jan 5, 2004 | 03:32 AM
cartman308's Avatar
the power loss will be negligable. you will have better stability with the c-series because thay have a wider offset making your bike wider!
most of you powerloss is due to the tires. Your not really losing power but gaining traction. Good tires wont break loose as quick making you think you lost power. at least thats the way i see it.
l8r
cart
Old Jan 5, 2004 | 09:13 AM
Cleve's Avatar
This is just a suggestion but have you looked at the Douglas aluminum rims (.190) thickness? There is no off-set with those rims and with 26 in.tires ,I don't think you will have to worry about rubbing. I have the c-series rims on my 650 and I do notice a slight increase in mud and crud being thrown on me because of the 1in. off-set. and the Maxxis tires that I have mounted are not a wide tire. The stock rims on my 650 are .160 aluminum and that's not enough strength on the rim for aggresive riding.
ReconBayou
Oct 16, 2019 02:24 AM
dannytas
Sep 26, 2017 06:31 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
