What sand tires for a Predator
Old Jan 6, 2004 | 04:30 PM
BoatGuy's Avatar
Default What sand tires for a Predator
Which tires work best overall for the Predator at the dunes? I will be duning a lot of the time and messing around racing the hill a little as well.
Which ones work the best for both stiuations?
What size do I want to go with? I have an 04 Predator.
Old Jan 6, 2004 | 04:47 PM
50021's Avatar
i would get v-paddeled tires they are good for recreational riding but can also be used in hill climbs
03 predator pipe and jet kit coming soon
Old Jan 6, 2004 | 05:44 PM
BoatGuy's Avatar
Which brand of tire?
I have heard good things about the Sand Stars. Any comments?
Old Jan 6, 2004 | 09:51 PM
powerslider's Avatar
Haulers are your best option, stock tire size. Gear down...
Old Jan 7, 2004 | 03:05 PM
BoatGuy's Avatar
Has anyone tried the Sand Stars?
I thought it took a lot of HP to run Haulers?
Old Jan 7, 2004 | 07:14 PM
The Predator has the power to run Haulers, drop your gearing to 13/37 or 13/38. The molded paddle tires weigh more which robs power. I have run Haulers for years, IMO they are the best sand tire....
Old Jan 9, 2004 | 08:40 PM
BoatGuy's Avatar
I have heard that Haulers break paddles every so often. Is there any truth to that? I don't want to keep buying new tires for only doing 2-3 trips to the dunes a year.
Thanks for your replies.
Old Jan 9, 2004 | 10:00 PM
2mnyToyz's Avatar
see how you are!
I have 13/38 gearing with 22x11x10 8 paddle hauler extremes. Best tire I've had. Good floatation on slow turns through the trees. Keeps you up on the sand for a good hole-shot after rounding a corner. The extremes are the same profile as the hauler, the bond on the paddles are stronger.
I had 20x10x10 10 paddle hauler extremes and just dug holes where ever I went. The machine will push them, it's just too many paddles for turning around trees. Good for drag-racing... that's about it.
Old Mar 23, 2004 | 02:55 PM
Graffer's Avatar
I can not find the Haulers in 20x11x10 size anywhere to match Predator rims. Anyone know if they make them and where to get at? Thanks
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
