warriors carb
Old Jan 12, 2004 | 09:29 PM
yaaaaaa's Avatar
Default warriors carb
I just got done rebuilding the top end and put a stock hi-compression wiesco piston in it. Now it wont start unless i prime it by dumping gas down the spark plug hole. It will run for a few minutes b4 i eventually end up killing it. It also has a K&N filter with a proflow intake. The quad sat for prolly 4 months with the carb just hanging there, do you think that i can just spray carb cleaner in the carb or do you think its the jets? Could it possibly be the new rebuild being stuburn???
Old Jan 12, 2004 | 11:05 PM
Crotts's Avatar
Did you bump up your jet size at all? The higher compression will need a larger jetting, but I think it is more than that. Make sure your carb is clean and check your cam and make sure your timing is right.
Old Jan 12, 2004 | 11:10 PM
Colby's Avatar
Are you sure hi-comp requires bigger jetting? More air means more fuel, higher compression doesn't achieve more air, just a more compressed combustion. Check your timing; make sure the line on the sprocket lines up WITH THE CHAIN TENSIONER INSTALLED. The PO of my Warrior lined them up, then installed the tensioner; end result was it was off by one tooth and ran like ***.
Colby
Old Jan 12, 2004 | 11:23 PM
Crotts's Avatar
I'm pretty sure you do. Well maybe not for lower compression like 10.25, but the higher ones you most likely will need to. I might be wrong, but I do know if you are running a piston that needs race fuel you must rejet higher or you will burn your piston.
Reactant
Mar 30, 2022 02:08 AM
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
Aitch
Jul 21, 2015 09:40 PM
Reactant
Jul 16, 2015 10:29 PM
