Rear Brake Lever Removal
Old Jan 13, 2004 | 11:43 PM
Puttnutt24's Avatar
Default Rear Brake Lever Removal
Hey guys,
Has anyone removed the left hand rear brake lever on thier V-Force which controls the rear brake? You know, where the clutch lever usually sit's. I never use it and I'm having a hard time installing it with the Trail Tech X-Bars. I thought about this before while on the trails and now have the perfect oppertunity to do just this. It looks like you'd just have to remove the lever and perch, cable to the rear brake arm and disconnect the brake light switch. Thx in advance, Rich A
Old Jan 14, 2004 | 12:12 AM
MentalState's Avatar
This is very easy to do ...Just dont loose the washer once you unscrew the wing nut on the rear adjuster.....
The only downfall is you have no rear brake light .Unless you are crafty enough to rig it up to the foot break lever?
good luck
Old Jan 14, 2004 | 04:59 PM
DesertSportsman's Avatar
and you loose your park brake
Old Jan 14, 2004 | 06:01 PM
Puttnutt24's Avatar
Thanks for the replys.
The rear brake foot lever also has a seperate brake switch so that isn't an issue but it was when I had everything removed and in my hand is when I noticed I lost my parking brake. On a manual shift quad I wouldn't mind this, just put it in gear, but on a V-Force I see this as a problem. Not so much as to reinstall the left hand lever however but to look at other options, one being another front brake master cylinder set up off another quad that uses the front brake as the parking brake. Most manual shift quads use the front brake as the parking brake too don't they? How about you guys on Kawi's 400's, is there a locking mechanizum on your front brake lever? Any other suggestions? I know my old DS-650 used the front brake, thx again, Rich
Old Jan 14, 2004 | 08:23 PM
Puttnutt24's Avatar
Man was I wrong, there isn't a ATV made which uses the front brake as a parking brake, man, guess that left hand brake lever goes back on, oh well! Putt
Old Jan 14, 2004 | 08:39 PM
Eric250EX's Avatar
2 words keep-it its there for a reason...or if your dum like me and dont put a th pb on and see your atv rolling down a dune
Sandman2.0
Jul 21, 2015 09:03 AM
Desimation2k8
Jul 17, 2015 12:37 AM
timster911
Jul 13, 2015 01:57 PM
tporath
Jul 11, 2015 12:31 PM
rcappie4
Jul 10, 2015 04:54 PM
