lt80 clutch mods
Old Jan 21, 2004 | 01:58 AM
yfz450bb07's Avatar
Default lt80 clutch mods
if i had a fully modified clutch, i can't list all of the stuff but it's a good mod, what is he best gearing setup? we do some indoor,outdoor mx and hit the dunes?
Old Jan 21, 2004 | 08:17 AM
LT80's Avatar
LT80 Expert
IMO: clutch mods without motor work is all but useless.
Old Jan 22, 2004 | 12:03 AM
yfz450bb07's Avatar
why is that? all i have is a fmf pipe
Old Jan 22, 2004 | 03:50 PM
LT80's Avatar
LT80 Expert
My reasoning: The LT in stock form has pretty good low end. Without porting, the RPM's won't change with clutch mods. Rpm's is where you get the speed from (stock=6500, modded=9800). You can mod the rear clutch to allow more travel of the sliding face, but aside from that all the other clutch work I do will not help in any other area.
Clutch mods are for once the engine is modded.It's then that it takes clutch mods to let the clutch's work with the motor for optimum low/top power
The FMF is a good pipe for a stock machine. My expierience with them once the motor is modded is another story.
You can power a bigger front sprocket. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 21, 2004 | 01:31 PM
ZukiSu's Avatar
I found this artical on clutches take the time to read all three parts there are some good diagrams worth keeping.
http://www.off-road.com/atv/kidskorner/clutching1.html
Old Jan 30, 2007 | 05:22 PM
tom450's Avatar
Could someone explain me what mods I can do to the front and the rear clutch ?
I think on the front one I can put out 2 rollers, but which one of the six ?
What can I do one the rear ?
Please explain it very exact, I am not a technical specialist.
Thanks
Old Jan 31, 2007 | 11:04 AM
LT80's Avatar
LT80 Expert
On the front you take out opposing rollers (across from the other).
On the rear, you need to cut the 3 shoes down to 180 grams each.
FYI:: the big nut is left handed thread.
http://www.nrys.com/fiche_select.asp
Go there to look at the parts blowup for the rear clutch...it's transmission 2...That should help on how to disassemble the rear clutch. [img]i/expressions/face-icon-small-smile.gif[/img]
QuadRiders
Oct 22, 2015 04:13 PM
merryman
Sep 19, 2015 03:15 AM
PrairieDog126
Sep 16, 2015 01:33 PM
Jaymc
Sep 11, 2015 07:45 AM
1ArmBandit
Sep 8, 2015 08:59 PM
