sprockets
Old Jan 21, 2004 | 10:51 PM
nyu's Avatar
nyu
Default sprockets
Where might I find a smaller front sprocket for a 2004 eton viper 90
I need to slow it down
Any aftermarket or racing places?
Thanks for replies
Old Jan 21, 2004 | 11:09 PM
spike99's Avatar
Default sprockets
Try...
http://www.atv-kids.com
http://www.wrhracing.com
http://www.dirtrides.com
http://www.miniquadracing.com
http://www.trinityracing.com
http://www.hi-pointmotorsports.com
http://www.hetrickracing.com
http://www.miniatvparts.com
http://www.hardrockmotorsports.com
http://www.rockymountainatv.com
http://www.moto-man.com/atv.pg
http://www.cyclecost.com -> ATV section
* Many of the above sell E-Ton parts as their main line or as a Special Order. Call or email each one because many of them don't show their Special Order parts on their web sites.
If you want to slow your E-Ton down, you may want to use its Throttle Control Screw. When your rider is ready for more speed, then turn the Throttle Screw out. Eventually, the Throttle screw can come all the way out. If you are looking for more bottom end power, changing its sprockets in one way...
Also, if you order from the states, be prepared to pay twice for a part (that ships across the US / Alberta border). Good old "no-Duty, + Processing fees, plus shipping, plus taxes" add up very quickly. Your local E-Ton dealer may sell the sprocket(s) you want via Special Order at a less final price.
Hope this helps...
Old Jan 21, 2004 | 11:29 PM
nyu's Avatar
nyu
Default sprockets
Thanks for the reply
I got my dealer looking today for sprocket
Thought I might find easily on web also
Old Jan 22, 2004 | 01:13 AM
polarispop's Avatar
Default sprockets
is e-ton and pred 90 the same bike
Old Jan 22, 2004 | 07:19 AM
TRexTommy51's Avatar
Default sprockets
No, Not true. THe Viper uses a 520 chain and the sprocket slips onto a shaft. THe Polaris is a 428 and it is splinded onto a shaft. You can get a set of sprockets for this machine from Hetrick or WRH. If they can't get what you want, then have Michelle at Hetrick call me and I will tell her where to get them. Tommy Richardson
Old Jan 22, 2004 | 11:28 AM
polarispop's Avatar
Default sprockets
Im talking about being able to use the speed limited polaris cdi to slow it down
Old Jan 22, 2004 | 12:52 PM
Default sprockets
OK, Sorry, you are correct. The POlaris Predator CDI will plug into your E-Ton and make it as slow as a snail.
Old Jan 22, 2004 | 07:35 PM
spike99's Avatar
Default sprockets
Tommy,
As a thought, would you recommend NYU remove his E-Ton CDI and replace with a Polaris CDI, instead of changing the chain sprockets??? If so, will his E-Ton CDI (with its green wire cut) fit on an '03 Pred-90 and make it go much faster. Perhaps someone like NYU and a Pred-90 owner, like myself, would want to trade CDIs??? Just an idea that may save 2 different people a few dollars...
Can anyone comment on this idea???
buddieboy
Dec 9, 2016 05:50 PM
merryman
Sep 19, 2015 03:15 AM
Canamaniac!
Sep 15, 2015 06:19 PM
Old Deer Hunter
Sep 2, 2015 01:39 AM
Dammar
Aug 26, 2015 07:12 PM
