oil on belt, 600 Grizz
Old Jan 27, 2004 | 08:02 PM
eiger2's Avatar
Default oil on belt, 600 Grizz
Why is it full of oil? Removed cover and full of oil.
Old Jan 27, 2004 | 08:20 PM
eiger2's Avatar
anyone?
Old Jan 27, 2004 | 08:42 PM
Chilly's Avatar
It's probably the crank seal leaking.
Old Jan 27, 2004 | 10:13 PM
eiger2's Avatar
I checked a parts fish site and saw the seal, Thanks.
Does this indicate a bad bearring? theres one next to the seal.
Old Jan 28, 2004 | 01:28 PM
Chilly's Avatar
It's not likely that the bearing is bad unless there are a lot of miles on the quad. Try moving the shaft up and down a little, there should be virtually no free play in the shaft. If it is the seal, it usually means splitting the engine cases to get it out and a new one in place. The only saving grace may be a seal carrier that is bolted onto the crankcase. If the 600 has one of those, it's not a big job.
Old Jan 28, 2004 | 01:34 PM
eiger2's Avatar
yes, iy looks like it does. Thanks
Old Feb 10, 2004 | 01:28 PM
eiger2's Avatar
Thanks chilly. I post a Yamaha question and only a Honda answers?
Well heres what we found. The seal was leaking bad (spraying oil all over). The guy apparently hasn't changed his oil in 2 years and the float needle in the carb wasn't seating properly so it was flooding the engine with gas. This eventually worked into the crankcase and thinned the oil, not to mention raising the level of the oil. When we drained the oil it was the ugliest oil I've seen in my life, Ohio river green.
We cleaned er out and sanded the belt. when she was back together the belt slipped bad for about 3 mins then started to grab then took off, wow!
Jeff Roper
Feb 1, 2022 11:48 AM
buddieboy
Dec 9, 2016 05:50 PM
Jeff Roper
Sep 21, 2015 02:11 PM
Ridgerunner665
Sep 15, 2015 01:20 AM
toonces
Sep 5, 2015 01:14 PM
