Oil Problem
Old Jan 29, 2004 | 12:11 AM
SuperMike2233's Avatar
Default Oil Problem
Checking my Rubicon out before I took it riding & when I looked at the oil it had nasty foam bubbles at the top & looked like milk. What do I need to do to get it clean inside before I add my new oil? Thanks
Old Jan 29, 2004 | 12:26 AM
KNOWSALOT's Avatar
The Facility
Default Oil Problem
You need to run through two changes at the least to be safe.
Change your oil along with a new filter. Run it until operating temprature. Change it again while the oil is hot [be careful]. Leave the oil filter in during this second change. Run it again until operating temprature and then replace the oil and filter and you should be done.
Alot of guys flush the engines with kerosene or diesel fuel. This is bad on the oil seals and rubber o-rings.
Old Jan 29, 2004 | 02:51 AM
swampdonkeykiller's Avatar
Default Oil Problem
Diesel Fuel is a petroleum product and is NOT bad on seals or O-Rings. I work with it every day and have flushed my swamped engines with it. Don't use straight diesel, but 1 litre for every 4 and you will not do any harm and it will help clean out your water faster than just straight changing the oil. You are mis-informed...
Old Jan 29, 2004 | 03:11 AM
KNOWSALOT's Avatar
The Facility
Default Oil Problem
First of all, every OEM makes it a point to let it's service departments know they strongly discourage the use of diesel or kerosene for engine cleaning purposes. They state it every shop manual and they are quick to point it out at nearly every servie seminar I've been to.
I use the stuff myself to clean things around the shop, but not to flush engines.
If you think I am misinforming supermike2233, then so be it.
I usually go by the book rather than the shadetree gazette
If it works for you then fine.......great.......I know others in here who do the same thing. But I'll never reommend it.
To each their own.
Old Jan 29, 2004 | 06:24 PM
Sandrider503's Avatar
Default Oil Problem
Go to your local auto parts store and grab some SeaFoam. I use it in my car, lawnmower heck you can use the stuff in everthing. It cleans and coats stuff to help with extra lubrication. Always run it by your dealer but I'am pretty sure it will be fine. That stuff is top of the line. Hope this helps
greg74
Sep 10, 2019 03:03 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
