Twist Throttle for P650/P700
Old Feb 4, 2004 | 08:37 PM
MikeyBoyesq's Avatar
Default Twist Throttle for P650/P700
I've heard that Mike Penland and Scott Kilby use twist throttles on their P700's for GNCC racing. Has anyone else on this forum used a twist throttle on the P650/P700? If so, where did you buy it/what brand and how does it compare to using the thumb throttle?
Old Feb 4, 2004 | 08:56 PM
Prairiewrench's Avatar
Get ahold of newbeatle (Mike Walker), he has done it to his Prairie
Old Feb 4, 2004 | 10:29 PM
p700wheelieman's Avatar
i've got a twist throtle on my 700p it's off a 400 prairie bolts right on cable is a little long though and you have to relocate the 4x4 switch motion pro was saposed to come out with a kit but i don't know how thats going good luck
Old Feb 5, 2004 | 08:42 AM
newbeatle's Avatar
MIKEY... I got you on another forum, but will post for the benifit of the others... I've had a twist throttle on mine for the last 8-9 months, raced a few hare scrambles & an Ice race with it so far... I'd never go back, but...
It takes some getting used to, if you rode a lot of bikes in your day, it'll be a natural...what I notice most ( negitively ), about trail pounding / hare scramble racing, is that when flying into corners, ( I ) have a tendancy to not be able to roll completely off the throttle... this keeps the KBEC from engaging as much as I was originally used to... I nearly got my self in trouble a few times racing, & training on the nasty trails I train on, but now, it seem like I've gotten used to it... I even installed one on our 300 Prairie ( just to make sure I stay used to it, & the wife complained alot about thumb fatiuge, even with the thumb extender on it )...
I used the Motion Pro model for the 400 Prairie... it will go right on, but there is a problem, as the 4 X 4 engagement switch is part of the thumb throttle ( Motion Pro was working on a kit for the 650 Prairie, when I ordered mine, like 8 months ago )... I took my dremel & cut a rectangle hole in my handlebar plastic ( initially, as I have removed my handle bar shroud now, & relocated that switch to my electrical panel ), to mount the 4 X 4 engagement switch... this worked really well...
It worked so well, that a few of my riding buddys that have a MC back ground have converted thiers as well... If you do it, just allow yourself the time to get used to it, before you put yourself in a position of pushing the limit ( as in racing )... if you never rode MotorCycles, & spend the bulk of your riding hours on a quad with a thumb throttle, you may not like it ??? But I can honestly say, that my thumb has not been sore from even an all day ride, since the install...
Old Feb 5, 2004 | 09:01 AM
trx450's Avatar
WVa Bartman has done the conversion. P.M. or email him.
Old Feb 5, 2004 | 10:02 AM
one thing i noticed with my twist throtle is if i run a thin grip like my yz 426 has i get bad arm pump you do a lot more muscling the bars around then on a dirt bike so i found a big fat full waffle grip and i like that some thing to hold on to
Old Nov 24, 2004 | 02:21 PM
jpsdiving's Avatar
Try a motion pro, they have full kits for the larger kawi's now.
Pehter
Oct 3, 2024 11:00 PM
wrencher82
Sep 28, 2015 10:02 PM
wrencher82
Sep 24, 2015 03:39 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
89Lt250r
Sep 7, 2015 07:53 PM
