reverse rev limiter override on RINCON
Old Feb 6, 2004 | 03:34 PM
DSAPP's Avatar
Default reverse rev limiter override on RINCON
is there a way to bypass or disconnect the reverse rev limiter on the Rincon??
Old Feb 6, 2004 | 06:49 PM
bigojaydog's Avatar
lol how fast do you have to go in reverse.
Old Feb 6, 2004 | 07:17 PM
LittleBoy's Avatar
Don't you have a button that says 'override' on your handle bar to remove that reverse limiter? On my 2002 Kawasaki Prairie 650, it's just below my 'start' button, and Yamaha Grizzlies you have to buy on aftermarket module that by passes this limiter, but I didn't hear about one for the Rincon.
Old Feb 6, 2004 | 08:43 PM
kawakasi's Avatar
I dont know how to help
but it probably sucks when ya get stuck
going foreward and that damn
reverse rev limiter wont let ya kick *** backwards
Old Feb 9, 2004 | 01:24 PM
goattrotter's Avatar
I did it this weekend and works great but is limited to certain amount of time, then you must turn the igniton switch of and bypass switch off to recet the ecm.
I am going to try another way this week or weekend so hang tight.
If the new way does not work The other set up will do for when you get stuck.
Later
Old Feb 10, 2004 | 01:04 AM
A freind of mine figured out a way. It is perfect. They should be done this weekend coming.No switch needed!
Old Jan 30, 2006 | 11:48 AM
kikit2's Avatar
I installed a siwtch according to someone's diagram on another website. Here's what I did, becuase I do want the switch. First I cut the grey wire and attached one end of it to the middle prong on my switch and the other end to one of the end prongs. Then I spliced into the blue wire and attached that to the other end prong. From what everyone says, this should work. But it didn't. Can anyone tell me what I might have done wrong???
Old Mar 5, 2006 | 11:05 AM
eiger2's Avatar
I could if I could find a wiring diagram.
I think I know where you saw it and those guys seem a lil confused on whats going on. I did it to my eiger. I used a switch. Now I want to do it to my Rincon.
kikit2, Ya goin to the Windrock spring Jamboree?? Maybee by then we will have all the needed mods worked out.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
r1pilot83
Sep 27, 2015 07:38 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
