has spark and gas
Old Feb 7, 2004 | 12:15 AM
Jeeptaz's Avatar
Default has spark and gas
1985 honda trx 125. it has spark and we took off the carb and put gas in and bike does not start. comp seems to be good. when we put the gas in don't seem like the spark plug is getting the gas. but we are putting the gas in the engine with the carb off. any ideals.
jeeptaz
Old Feb 7, 2004 | 12:58 AM
hondabuster's Avatar
Have you ever seen it run?Did you buy it like this?
Youre right to check for spark, and fuel. Only thing else is compression.
You need to make sure you do have good compression. use a compression gauge, youll need 80 psi or more.if not good enough Check for valve clearance. Check valve timing.
Im not sure youll be able to get it to fire , with the carb off. The mixture will be very lean, and have very low velocity.
Did the spark look good and strong?
Old Feb 7, 2004 | 01:13 AM
ThrashAndCrash's Avatar
Check the Valve clearance (.003in). If you need ANY other specs on this engine let me know...I have books out the waazooo on this engine.
fordfaithful21
Dec 7, 2015 05:52 PM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
Cdenton
Technical and How-To Articles
Sep 9, 2015 11:23 AM
MrTrashMan2U
Sep 9, 2015 11:11 AM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
