cheapest place to buy a 360 belt?
Anyone out there know where the cheapest place to buy a belt for a 360? And what seems to be the amount of Km's you can get out of a belt before you need a new one? I just had my belt tightened at the dealer and it still squeels. With only 1020kms on it.
Last I heard, http://www.worldofcycles.com/ was the cheapest place to get belts.
Also, if your dealer doesn't successfully adjust your belt and take care of it for you to your satisfaction, you should be doing it yourself. It really isn't hard and you will know that it is being done right. There is plenty of knowledge in this forum to help you with it. Your belt should last long, not squeal at takeoff. If it squeals at idle it is OK, as it will last longer that way. Do not drive it if it squeals at takeoff, since it is too loose and/or glazed and will wear the pulley out real fast.
Hey Mudmonkey72, we have that belt in stock!
You can find it here: http://www.atvworks.com/products.asp?id=47
Thanks,
scott
www.atvworks.com
Thanks,
scott
www.atvworks.com
Jeff Roper
Feb 1, 2022 11:48 AM
