K&N for Sportsman
Old Jul 4, 2000 | 03:29 PM
texasduck's Avatar
I put a K&N on my SP500 - I use them on my race karts, trucks, everything.
Did anyone use the prefilter/charger from the stock filter over the K&N or did you go with a K&N or Outerwear prefilter?
Is rejetting really necessary in low altitudes? Plug looks fine. That should be the determining factor, correct?
Thanks
Old Jul 4, 2000 | 03:35 PM
stevie's Avatar
I have two k&n and one has the stock cover and the other has the k&n cover. I dont think it really maters
Old Jul 4, 2000 | 06:14 PM
seacow's Avatar
I have the K&N and Outterwear prefilter, You should tweak your fuel / air screw so you get all you can from your 500 CCs, remember all stock main jets come fat from the factory, the increased air flow from the K&N will help lean you out but probly not enough. It's pretty common to drop 10 on the main right out of the crate.
Old Jul 5, 2000 | 11:44 PM
KevinOK's Avatar
I just put one on my Magnum 500, have not had a chance to ride it yet.
Will there be much noticable differences?
Also, any recommendations on tachometers to set idle speeds to 1200 rpm's?
Jmuddin284
Jan 19, 2026 07:16 AM
chingchangchong
Aug 7, 2022 11:36 AM
slowgsxr97
Sep 8, 2015 07:33 PM
Pahuntman
Sep 5, 2015 11:07 AM
cdstang
Aug 31, 2015 07:52 AM
