hpd clutch kit
Old Feb 16, 2004 | 04:04 AM
csamayfield55's Avatar
Default hpd clutch kit
I am gonna gat the HPD clutch kit to go with the new pipe so now the ???'s start.
Do I need any special tools fo the install of this kit or is it an easy bolt on?
Have any of you tried there belts or should I look for a dayco?
Thanks
chris
Old Feb 16, 2004 | 12:50 PM
modquad's Avatar
Any of the kevlar reinforced belts are great. You'll probably need a primary and secondary clutch pullers. Take your time and mark the inner and outer components w/ a permanent marker. If you don't have a clutch compressor for the secondary, I used to use a roll of masking tape. Makes things easier w/ the rounded snout of the secondary clutch resting down on the (laying flat) roll of tape. Also for ref, you can mark the helix and sheave positions after the spring is released. I use a red and a black marker, one for each postion. Also there are "X"s on the primary clutch cover, and the clutch itself, make sure they're lined back up when you put it all back together.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
