Broken front sprocket..Help
Old Feb 26, 2004 | 08:55 PM
bearaf's Avatar
Default Broken front sprocket..Help
I broke several teeth off the front sprocket of my 98 sport. I have the rear disk brake right in front of the sprocket. How do I change the front sprocket? Do I have to take the rear disk brake off? Any help will be greatly appreciated!
Thanks
Old Feb 26, 2004 | 10:07 PM
quadwrench's Avatar
Nothing to it - remove the chain, remove the brake caliper (two 1/2" bolts) - remove the brake disc - remove the bearing plate (two 9/16" nuts w/square head bolts on back side) - remove the snap ring in front of the sprocket and slide the sprocket off - reverse putting back together.
Heres a diagram to help you out: '98 Sport drive sprocket
Old Feb 26, 2004 | 10:26 PM
bearaf's Avatar
I'm down to the snap ring and so far it has been a snap, but is there a secret to getting that snap ring off? Oh yea did I mention I'm kind of fix it illiterate!
Thanks
Old Feb 26, 2004 | 10:32 PM
trailrider500's Avatar
You need to get yourself some good snap ring pliers... like these...
Trailrider
Old Feb 26, 2004 | 10:46 PM
bearaf's Avatar
Ohh I see, that would be helpful, I've been trying with just a pair of needlenose and they haven't worked real well!
Thanks alot!
Old Feb 26, 2004 | 10:47 PM
Not a problem at all anytime[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 26, 2004 | 11:50 PM
bearaf's Avatar
I got the snap ring off and now the sprocket won't go past the swing arm bolt! I guess I'm going to have to pull that whole thing off. What a pain! Know any tricks to get it past that point? I guess it woouldn't be any fun if it was easy!
STLyamwar
Jul 25, 2020 04:44 AM
greg74
Sep 10, 2019 03:03 PM
DeFox500
Jul 26, 2015 06:32 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
