alcohol?
Old Mar 5, 2004 | 12:03 AM
Haulinonthedunes's Avatar
Default alcohol?
Can you run alcohol in a mikuni tm45 carb with a 12:5:1 compression piston or is there more mods or a different carb required to run it. Thanks
Old Mar 5, 2004 | 12:07 AM
QUADMAN650's Avatar
Default alcohol?
OH YEA!
If you want to try it just take the main and pilot jet out drain gas and poor alky in the tank what a rush!
Old Mar 5, 2004 | 12:23 AM
beachbum's Avatar
Default alcohol?
sounds like a drug[img]i/expressions/face-icon-small-cool.gif[/img]
Old Mar 5, 2004 | 12:41 AM
Default alcohol?
Where do u buy the alky from or where do u order it. Thanks
Old Mar 5, 2004 | 01:05 AM
1BigDSRider's Avatar
Default alcohol?
Check for local dealers in your area.
Old Mar 5, 2004 | 03:03 AM
XR650Warrior's Avatar
Default alcohol?
order through your local drag strip by 55 gal. drum, should be around $125.00, and get you a pump and you'll be ready, it will run without a pilot and main to try out but if you're gonna stay with alky. you need to convert the carb. -- Ron Woods has a kit to change needle + seat, main tube, jet needle, mains + pilots. Get it DRUNK [img]i/expressions/face-icon-small-happy.gif[/img]
Old Mar 6, 2004 | 10:30 PM
MrMeaner's Avatar
Default alcohol?
Good advise XR. Woods racing has a good kit. No pilot needed. Rotax.net for Woods Racing
sugarhead
Jun 15, 2002 08:04 AM
pudjumper
Apr 26, 2001 01:11 AM
cowboy
Apr 18, 2001 03:22 PM
b370
14
May 1, 2000 12:51 PM
