my clutch is dead and i cant take off the side cover
Old Mar 6, 2004 | 02:33 AM
cOoLdevil's Avatar
Default my clutch is dead and i cant take off the side cover
hi all and last night i tryed to take off the clutch side cover and i notes that i cant takeit off it seemed that its stuck in some thing and i cant take it off and the clutch shaft that holdes the cable in it is rotating by hand so easy and thear is some crashing sound coming out and i think i realy smash it up real bad so did any boddy face this broplem before and how to get it out the side cover and help or pic of how to get it out ???
Old Mar 6, 2004 | 10:13 AM
BajaIowa's Avatar
Make sure all the bolts are out including the ones that hold in the starter. Make sure everything is out of the way including nerf bars and footpegs. You also have to take off the water pump cover and the shift lever. When everything is loose then tap the cover with a rubber mallet and it should then slide right off. As far as the bad sounds, some people have had the gear strip out that pulls the clutch basket. This is what is attached to the pivot arm.
Justin
ghost civic
Jan 15, 2020 07:43 AM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
ghost civic
Jul 15, 2015 10:48 PM
Countrygirl1976
Ask the Editor
Jul 13, 2015 12:19 AM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
