85 125m timing
Old Mar 14, 2004 | 11:28 PM
kevnk's Avatar
Default 85 125m timing
help
I need to know how to set the timing chian corretaly on my 85 honda act125m
also does any one has some cheap power upgrades for this trike.
thanks alot
Old Mar 15, 2004 | 03:37 PM
ThrashAndCrash's Avatar
my books aren't too clear on your engine but it should be.....
Cam mark goes up ( should be a casted mark in the valve cover at the centerline of the engine)
Crank mark is the same way but use the "T" the "F" is for fire use this to set your ignition, but set your ignition with the right case half tem. installed because the timing hole has a arrow in it and you can get it real close! Hope this helped
Sjrpp
May 2, 2023 03:59 PM
slowgsxr97
Mar 18, 2022 03:40 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
95wolv
Jul 17, 2015 08:13 PM
