85 125m timing
my books aren't too clear on your engine but it should be.....
Cam mark goes up ( should be a casted mark in the valve cover at the centerline of the engine)
Crank mark is the same way but use the "T" the "F" is for fire use this to set your ignition, but set your ignition with the right case half tem. installed because the timing hole has a arrow in it and you can get it real close! Hope this helped
