Any thoughts on running synthetic oil.....
Old Mar 17, 2004 | 03:06 PM
Lancester's Avatar
Default Any thoughts on running synthetic oil.....
in a TRX-450R? I know it can't be run in the transmission,but how about the engine side? I use MOBIL one 10-30 in my SRT-4 and would like to use it in the Honda as well.Discuss......
Old Mar 17, 2004 | 03:53 PM
ryangibson's Avatar
Synthetic has nothing to do with friction modifiers. You can even run full synthetic in your tranny...the trick is finding the RIGHT synthetic...and paying for it. I'm planning on running the Honda HP4M in the engine, which I believe is a semi-synthetic, and the HP tranny oil for two-strokes in the tranny.
As for running full automotive synthetic in your bike, don't do it. Just because it's "automotive synthetic" doesn't mean that it's better. You need to run API SG or SH grade oil in your bike. The higher grades actually have less protection than the older SG. Also look for JASO MB for your engine side, and JASO MA for your tranny. MA is without friction modifiers, MB is with.
Basically, just make sure that if you do run full synthetic, it has an API grade of SG or SH, not SI, SJ, or any other higher API rating, and you'll know you are running the best oil you can run.
Old Mar 17, 2004 | 08:30 PM
VeryPicky's Avatar
I'm useing Mobile 1 MX4T 10W40 motorcycle oil in my Rincon. Fully synthetic, API SG,SH/CF, JASO MA. No friction modifiers. This is a full synthetic that you "CAN USE". Kind of pricey though, $8.99 a qt at auito zone. Mobile also has a line of 2-stroke oil's. Go to their web site.
Old Mar 17, 2004 | 08:38 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
http://www.thumperfaq.com/oil.htm
Great article! Everything that applies to the CRF's, applies to your TRX! Also,
http://forums.atvconnection.com/mess...&keyword2=450R
Why not pick a blended oil? Petrolium oil is slicker (the molecules are smaller and irregular) and synth stands up to the heat and wear better. A blended oil has the best of both worlds! My choice for the 450 is Honda HP4M (with moly) for the motor, and Honda HP Trans Oil for the trans.
Old Mar 17, 2004 | 09:32 PM
honda450es4x4's Avatar
How about running synthetic oil in a honda foreman 450??
thanks
Old Mar 17, 2004 | 10:36 PM
cals400ex's Avatar
if you want you could run synthetic in your foreman. you won't notice much difference though
i run mobil 1 15w50 in my 406ex with good success.
Old Mar 18, 2004 | 01:57 AM
Red Rider
Honda recommends dino oil only (GN4) for its autoclutch bikes, like your Foreman. If you read the back of the HP4 (dino/synth blend), it says not for autoclutch bikes. I think synths can make the centrifugal clutchs slip.
TegraQuad
1) Engine problems..
13
Nov 26, 2017 01:40 PM
wannabe32
Jul 7, 2015 11:30 AM
Hondapolaris8596
Jun 19, 2015 11:19 PM
SlyFox
Jun 2, 2000 11:09 PM
c4drm
Jan 2, 2000 08:15 PM
