ITP C SERIES WHEELS
Old Mar 18, 2004 | 04:41 PM
BigVtwin's Avatar
Default ITP C SERIES WHEELS
I'm thinking of buying some of these for my p700. I was wondering how much lighter are they then the stock rims, im gonna put 26" mudlites on them. Is it worth it?[img]i/expressions/face-icon-small-confused.gif[/img]
Old Mar 18, 2004 | 04:55 PM
newbeatle's Avatar
They will be heavier, but stronger than the stock wheels... basically the stock wheels are as light a duty wheel ( equal to .160" stamped aluminum wheels like Douglas ), as most people would ever want to run... the C series are actually pretty heavy compared to the other stamped aluminum wheels... the type 4's are heavier than the type 5's, which are a little heavier than the type 6's... all of which are heavier than the Douglas & ITP .190" wheels...
Old Mar 18, 2004 | 05:15 PM
maddog56's Avatar
i was pretty sure that the c series were lighter than the stock steel wheels. I know that the douglas and itp wheels are .160 and .190, not .019 thickness. difference in the 4 and 5 is pattern, lighter weight on the 5, and a stronger wheel edge. The 6 is chrome like and has the same design as the 5 and the 6 has an even stronger rolled edge.
Old Mar 18, 2004 | 05:22 PM
newbeatle's Avatar
The stock wheels on the 360 / 650 / 700 Prairies are & have always been aluminum... the older 300 Prairies, & perhaps the 400's ( not sure about the 400's ), where steel though...
I'll have my type 6's tommorow... I could throw them on a scale to see about the weight... I was under the impression that the type 6's, had the same ( but milled thinner & polished ) rim as the type 5's ???
oooops... typo on the .019"...LOL
Old Mar 18, 2004 | 05:54 PM
maddog56's Avatar
I read on itp's website that it had a stronger rolled edge than the other 2. I may have misread, but I'm pretty sure about it. I had a set of type 4's on a honda rancher. I'm in the market for more for my p and was checking them out.
Old Mar 18, 2004 | 06:10 PM
trailride's Avatar
It was my understanding that the stock prairie wheels are stamped steel, and the new type 5 and 6 itp are cnc milled aluminum. Im not sure but the type 4 are cast. The reason i say the stock prairie wheels are steel is that when the bend you can beat it back straight , now aluminum will crack when you do that. An easy way to see would be to take a knife and scratch the backside of the wheel , under the paint you should be able to tell what they are.
Old Mar 18, 2004 | 06:15 PM
lafngas's Avatar
My stock wheels on my Kodiak were steel and weighed 8 pounds and my new c-series weigh 9 pounds..I hope this helps ya.
Old Mar 18, 2004 | 06:19 PM
newbeatle's Avatar
TRAIL... get your magnet out... they are all aluminum... cast aluminum won't bend very well, but stamped aluminum was bent into that shape in the 1st place, & though it will work harded, you can bend the bead areas several times, before it will get brittle enough to break...
Old Mar 18, 2004 | 06:21 PM
trailride's Avatar
Didnt think about the magnet trick. Ill try that
Old Mar 18, 2004 | 06:29 PM
maddog56's Avatar
Replacement front wheels are 78 bucks a piece. They are steel, at least on the 2004 models.
