stuck bolt
Old Mar 20, 2004 | 01:12 PM
manual's Avatar
Default stuck bolt
Well right now im in the process of taking out some 10mm bolts. I could get one free and the rest are stuck. I stripped my 2 10mm sockets trying to remove them, and it says 10mm on the bolt head. I sprayed WD 40 on a couple to see if that would make a differnce but there still in there. Does anyone have a good idea how to remove them?
Old Mar 20, 2004 | 01:25 PM
Raptorboy4life's Avatar
Default stuck bolt
could you hit it a little bit then kind of jiggle them with TWISTERRRRRR (inside joke) twister is a better type of wd 40! but if all else fails grind off the head and then ust plires to take it out but you would also need to buy a new bolt
Old Mar 20, 2004 | 01:28 PM
manual's Avatar
Default stuck bolt
Buying a new bolt isnt a problem. Lots of 10mm bolts at ace hardware, I may end up doing that. I will start back up on it tonight. Getta see my friend who finally went back home from his quadwreck
Old Mar 20, 2004 | 01:38 PM
AngryHampster's Avatar
Default stuck bolt
try penetrating grease and vise grips.
Worked on my truck ever time
Old Mar 20, 2004 | 01:50 PM
manual's Avatar
Default stuck bolt
Hmm sound like i explained this wrong. I guess I should have called it a screw.
Old Mar 20, 2004 | 01:52 PM
trailrider500's Avatar
Default stuck bolt
Get this stuff called PB-Blaster, its far better then wd-40.. I use this stuff everyday at work on rusted bolts on light equipment works every time..
You can find PB-Blaster at wal mart
If you can heat them up a little that works the best....
Old Mar 20, 2004 | 02:11 PM
rosebud's Avatar
Default stuck bolt
try tapping them with a hammer, and or heating them up vibration and heat will brake loose any rust or corrosion usually works every time also if it is a screw they make a impact screw driver just be carefull with one of these they sometimes break the head off! and that sucks I hate drilling and tapping. Good luck
Old Mar 20, 2004 | 02:29 PM
Default stuck bolt
its a socket screw right? you can grind part of the head and take a flat screw driver and use that!!! also twister is just the same as PB-Blaster but the PB-blaster somtimes weakens the paint on the aluminum and it flakes off!!
Old Mar 20, 2004 | 02:30 PM
Default stuck bolt
what i mean is that stuff is really good and can take off many many bolts especially in rust but it could be too much somtimes!!!!!
Old Mar 20, 2004 | 02:54 PM
manual's Avatar
Default stuck bolt
Raptor I was thinking of grinding the screw slots, but theres quite a few of thouse I need to do, had to do that on my carb when the philip head screws where stripped.
Jeff Roper
Feb 1, 2022 11:48 AM
Joe454
Nov 20, 2020 01:19 PM
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
mrtidy
Feb 3, 2016 05:00 PM
Jackg17
Sep 26, 2015 09:30 PM
