U joint
Old Mar 20, 2004 | 09:54 PM
pvinson's Avatar
Default U joint
Decided to change my CV boots(both torn) on my Scrambler 500 4X4. Did one side and found a bad u joint on the drivers side. To remove the yoke from the case I have to revove the pin. Do you Grind, drill, and or pound it out? And does the U joint press out like a car?
Thanks Paul
Old Mar 20, 2004 | 09:59 PM
trailrider500's Avatar
Default U joint
they should be like u joints on a car... I would drive that pin out with a punch...
Old Mar 20, 2004 | 10:06 PM
thewayout420's Avatar
Default U joint
yeah use a punch a tiny bit smaller than the pin and pound it out..and the u-joints should be the same as trucks are..
89Lt250r
Sep 7, 2015 07:53 PM
Ferhat Durakovic
Aug 26, 2015 07:04 AM
pro94lt
Aug 20, 2015 10:02 AM
toonces
Aug 13, 2015 12:40 PM
Peter_
Jul 18, 2015 07:06 AM
