my scrambler is slow!!
Old Apr 7, 2004 | 03:03 AM
scrambler123's Avatar
Default my scrambler is slow!!
I just rebuilt my scrambler with a stock bore wiseco piston it has a hpd trail pipe, 39pwk carb, reed spacer, clamp on k&n, clutch kit, evcerything it doesnt need removed, and it is still slow i went to the dunes this weekend and wasnt impressed i was getting beat by piped z-400s. any ideas why it is so slow or do i just need to keep pouring more money into the piece of junk.
Old Apr 7, 2004 | 03:36 AM
1fastpolaris's Avatar
It sounds like you need to spend more money. do you have any porting done? It sound like you are just set up for just trail riding only. Going to the dunes is totaly a whole new ballgame. Call Dennis with az bad boyz and tell him what you want to beat and he will set you up. 602-696-5875
Old Apr 7, 2004 | 05:15 AM
do they have a web site? do they do better work the hpd or rcr? thanks for the help
Old Apr 7, 2004 | 05:29 AM
fishslab's Avatar
Do you know how fast slow really is? I'm just wondering how fast you are over a stocker.
Old Apr 7, 2004 | 08:54 AM
POLARISFREAK's Avatar
There are lots of variables to consider here, the bike is lightened, but how much do you weight? What rear sprocket are you running, can't always go with the gearing other people recommend. What type paddles are you running and how many paddles are there. What is the condition of your belt, is it sticking out of the secondary by an 1/8 of an inch. Is it the complete hpd trail mod clutch kit, if so did you get the secondary preloaded correctly?
Old Apr 7, 2004 | 01:10 PM
I weigh #160. I have 14/36 gearing. complete aggressive clutch kit im running red/yellow primary, stock weights, violet secondary in the 1,2 position i believe it is preloaded correctly. I run 22x10x8 dune hoppers with 8 paddles. My belt is brand new only one ride on it. thank you for the help i appreciate it
Old Apr 7, 2004 | 01:23 PM
CED's Avatar
CED
You should be in the 2-2 position on the secondary.Try the 13 front also and see what happens.
Old Apr 7, 2004 | 02:13 PM
Definately put it in the 2-2 position. I had the same setup as that, with that gearing and the red/yellow, your not going to have much topend at all. I would actually go up on gearing or go to a plain hpd primary. Your pretty light with a decent amount of weight of the quad. Those are pretty heavy paddles as well, when you can I'd get a set of 21/12/8 8 paddle exremes.
Old Apr 7, 2004 | 02:17 PM
Redbullssg's Avatar
I would say clutching for sure.
Old Apr 7, 2004 | 02:36 PM
I used to run the 2-2 but the 1-2 woked better for me.
