I'm having trouble starting my 2002 500 (first start this spring)
Old Apr 10, 2004 | 12:10 AM
wapenn's Avatar
Default I'm having trouble starting my 2002 500 (first start this spring)
It's about 30 degrees out... first time I've tried to get the 500 started since last fall. I sprayed engine preserver in it before storing it away (inside the quonset at the farm). I put Sta-bil in the fuel too.
It's getting spark and seems to be getting fuel too... turns over great, but not even a pop. Anything else I can try ? Note: it's always been a little "cold-blooded".
Thanks in advance...
From Boondocks on the Northern Plains.
Old Apr 10, 2004 | 05:15 AM
hondabuster's Avatar
Does it have a primer? if so use that.
Does it have a pri position on the fuel valve? Use that.
If you open the valve on the bottom of the carb, does gas come out? This just verifies that gas gets to the carb.
Try holding your hand over the air intake snorkle, and block it about 95%, and while holding your hand there...spin it over. This will work like a real choke, and it should start up.
let us know how it goes.
Old Apr 10, 2004 | 11:32 AM
Smallcat's Avatar
Try a new spark plug. Happens all the time that you get spark outside cylinder but not enough inside.
Old Apr 10, 2004 | 03:20 PM
wapenn's Avatar
Thanks for the replys guys. (I'm a poet and I didn't even knowit. 8-))
Anyway, I found the primer, but that didn't help. I put a new plug in, gave the carburator a couple of gentle taps with the handle of a screwdriver (to potentially unstuck the float valve) and she took right off.
Thanks again. Now I get to see what she'll do in a little snow.
Happy Easter.
Old Apr 11, 2004 | 11:47 PM
luvthemud's Avatar
there was a service bulletin for hard starting, not sure if it was only on the 400's though.
Mkp
Mar 28, 2020 03:50 AM
buckshit
Sep 24, 2015 08:49 PM
Dakosk
Jun 6, 2015 05:37 PM
1000gade
May 27, 2015 12:37 PM
PLEA$URE
8
Jan 31, 2000 10:55 PM
