comet 103
Old Apr 18, 2004 | 09:13 PM
xplore50097's Avatar
Default comet 103
Has anyone tried a comet clutch on a 500 ho? , if so how is it ? good, bad or not worth the money and time.
Anybody have the clutch on a 400 scrambler? is this 103phq clutch a scam or worth the investment.
any info, rants or raves. I just got to know
Old Apr 18, 2004 | 09:17 PM
thewayout420's Avatar
Default comet 103
i think modquad runs the comet clutch..
Old Apr 18, 2004 | 10:24 PM
lslubecki's Avatar
Default comet 103
I have one on my 99 scrammy 500 4x4. It came with the a-1 arms (48.5 grams) and the black spring (50 lbs at 2 1/8" and 198 lbs at 1 1/8"). Shift out was way too high for me. It was like a high stall converter and was terrible for trail riding. My guess on rpm was about 2500. I switched to the a-54 arms (54.0 grams) and the shift out was better maybe 2000 to 2200 rpm but still too high. Then I went with the pink spring (45lbs at 2 1/8" and 142 at 1 1/8") and shift out was more like stock with maybe 5-700 rpm higher engagement. I thought I might try a stock spring and see what happens. As it is now I can race my buddies 2003 400 4x4 scrammy and from a dead start we stay together for about 1-200 feet then he starts to pull away. I havent looked for a wider belt or tried to machine the sheaves to take advantage of the larger diameter and higher speed that would follow. I bought it because it was cheaper than a stock replacement.
Steve Lubecki
Old Apr 19, 2004 | 07:49 PM
Default comet 103
Thanks for the info, must not be to popular or a clutch!, I had one given to me .
I mite play with it or sell it I don't know. My brother did't like it, so I gave him a stock
clutch set up. He had a hotseat green spring and W weights from hotseat in the comet.
He had to hi of an engagement and no topend and a lot of engine vibation,he had this on
his SP500non HO converted to a HO, (cam and carb ) He was trying to make a ute in to a sport
not happning.
Old Apr 19, 2004 | 07:57 PM
Default comet 103
Now he is happy , stock clutch, borring bluegreen spring and stock weights primary clutch,driven clutch
is borring red spring in 2+2 setting.
OleManMoses
Nov 27, 2005 11:59 AM
Fixitmatt
Aug 19, 2005 07:18 PM
blueslover
Jul 30, 2005 08:10 PM
Uinthas
Jan 26, 2005 04:45 AM
trenchdigger
Aug 28, 2003 07:25 AM
