whats the plastic gear everyone is talking about to be carefull of when doing clutch?
Old Apr 19, 2004 | 07:57 PM
saint650's Avatar
Default whats the plastic gear everyone is talking about to be carefull of when doing clutch?
in the next few days i am about to do my clutch. just waiting on a side cover gasket. ive read alot of the old post on doing the clutch and read alot of a plastic gear the will break the teeth if not lined up properally. what is this gear how do i look out for it?
Old Apr 19, 2004 | 08:00 PM
BajaIowa's Avatar
I have had the side cover off about six times in the last couple months and the only plastic gear I have seen is the water pump gear. The main thing to remember is to be careful and not force the side cover on. When everything is lined up it will just slide on. Check your clutch actuator rack to make sure that none of the teeth are broke. That is what I have replaced three times in the last few months.
Justin
Old Apr 19, 2004 | 08:02 PM
saint650's Avatar
thanks. do you have to align the waer pump to anything on the cover? seems stright forward but just want ot make sure
Old Apr 19, 2004 | 08:10 PM
BajaIowa's Avatar
I doesn't have to line up with anything, the gears just have to mesh. The clutch rod that the cable hooks to needs to be lined up. The easiest way that I have found is to make a mark on the cases where it is now and it will turn as the case comes off. When you slide it back on you will see if it is back where it is supposed to be. Good luck and make sure you soak your plates and fibers in oil before you put them in.
Justin
ghost civic
Jan 15, 2020 07:43 AM
Captjay
Jul 23, 2015 12:33 PM
ghost civic
Jul 15, 2015 10:48 PM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
