secondary clutch
Old Apr 20, 2004 | 07:21 PM
Powerstrokinsportsman's Avatar
Default secondary clutch
how much different does the secondary clutch work if you run the spring in the 3-1 or 3-2 position? I currently am running in the 2-2 position but was wondering what it would be like if I where to swith it. Any help? And its on a 400 scrammy if that helps
Old Apr 20, 2004 | 07:26 PM
ftwflh's Avatar
It will effect the back shift alot and add or reduce belt effetency.Depending on the spring 2-2 is excelant for trails but 1-1 my give you a little more topend.
Old Apr 20, 2004 | 08:03 PM
BigBadScrambler's Avatar
The HPD violet secondary spring set on the 2-2 posistion is very good on the trails, like ftwflh mentioned
Old Apr 20, 2004 | 08:05 PM
ftwflh's Avatar
If you have an older Scrambler I like the Aaen blue for trails.
Old Apr 20, 2004 | 08:52 PM
Bubba297's Avatar
2-2 or 1-1 is best for about 99.5% of all situations. The 2-2 is preferred if you do a lot of technical slow riding or hill climbing. Other than that, I like the 1-1.
Old Apr 20, 2004 | 08:56 PM
thewayout420's Avatar
what setup will give you most bottom end and what will give you most top?im set at 2/2 now with a hpd aggressive clutch kit,id like a little more top and bottom end..
Old Apr 20, 2004 | 09:04 PM
Bubba297's Avatar
A tighter setting will give you more bottom but less top. Just the opposite does the reverse. What kills everything is when you get it too much one way or the other. Too tight or too loose makes the clutch lose it's effeciency and that makes you lose power. Maybe not a lot, but it needs to be right.
Old Apr 20, 2004 | 09:48 PM
thanks bubba,im glad your around[img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 20, 2004 | 10:03 PM
Redbullssg's Avatar
Which is best for the dunes? I have a hotseat pipe and clutch.
Old Apr 20, 2004 | 11:17 PM
Bubba297's Avatar
I would say if you like to run dune hills and what-not, then go with the 2-2 setting. That will let the clutch backshift better and do better in the sand.
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
Steeldon
Sep 9, 2015 09:38 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
