Banshee Clutch! Help!!
Old Apr 22, 2004 | 07:46 PM
Chazzman's Avatar
Default Banshee Clutch! Help!!
I just put all new fibers and metal, clutches in my shee.. Now i have no clutch, like no pressure at the lever. What would cause that i got all the bolts and it all back to gether, is there something i could of messed up in addjustment or something?.. If you have any ideas let me know gota have it going for this weekend..
Thanks, Charlie
Old Apr 23, 2004 | 02:55 AM
OrganDuner's Avatar
My guess would be that you have something incorrect in the center of the pressure plate. There's a ball bearing that goes in before the center shaft also. If you have a repair manual, I recommend reading that section. Good luck.
Old Apr 23, 2004 | 03:13 AM
Sandragggen's Avatar
I helped my son put in a new clutch this past weekend and had the same problem. The clutch is out of adjustment. Loosen the nut on the center bolt on the clutch and then screw the bolt in or out with a phillips head until you have it adjusted where you want it then tighten the nut back up. It doesn't take much turning of the bolt to get you your clutch back.
JMiller
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
