Drive Clutch??
Old Apr 23, 2004 | 01:40 PM
suds's Avatar
Default Drive Clutch??
I got I drive clutch puller, which is basically a big bolt with a handle. To remove my drive clutch to I just keep screwing this big bolt in there. It is in their quite a aways with no result, it will let me turn more but, i;m not sure if i,m supposed to. Can someone pleease let me know how to remove my drive clutch.
Old Apr 23, 2004 | 02:12 PM
CED's Avatar
CED
If you are talkin about the primary ,yes keep on turning.If it gets to a point where it wants to stop.Give the puller a good tap with a hammer.
Old Apr 23, 2004 | 05:20 PM
suds's Avatar
Ok, ive erached the point where the bolt will not turn any more, How is the primary supposed to come out. should I pull outwards on the puller even harder than Ive been doing?
Old Apr 23, 2004 | 05:48 PM
CED's Avatar
CED
If you are at the point where it is tight,then give the puller a couple of good blows .What you are actually doing is pulling the clutch off of the shaft,it is a tapered fit.
Old Apr 23, 2004 | 05:52 PM
suds's Avatar
So should I keep hitting it with a hammer until it comes off?
Old Apr 23, 2004 | 05:56 PM
thewayout420's Avatar
just tap it a few times and try to screw the remover in a little more and repeat the process until it pops off..
Old Apr 23, 2004 | 05:58 PM
CED's Avatar
CED
Some people put some grease on the threads of the puller,you may want to try this also.You are basically pushing against the crankshaft.Give it a couple more taps with the hammer,and try tightening it a little more.
DGScrambler400's Avatar
just keep tapping and turning, you'll get the hang of it..
Cummins Driver
Sep 11, 2019 01:22 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
ghost civic
Jul 15, 2015 10:48 PM
clsharky
Jul 13, 2015 02:07 PM
