Fourtrax 300 startup problems
Old Apr 24, 2004 | 12:56 PM
Rhames's Avatar
Default Fourtrax 300 startup problems
I recently bought a 1999 Fourtrax 300 for me and the wife. Fired it up this morning first thing with no problem. Didn't run it but a minute or two then shut it down. Went out to start it up again about 3 hours later, now it won't turn over. Any suggestions?
Old Apr 24, 2004 | 04:12 PM
hondaguy2's Avatar
bad spark plug?
Old Apr 25, 2004 | 01:42 AM
hondabuster's Avatar
Im assuming the motor wont spin, when you press the starter button?
Check kill switch. Then try the pull starter, will the motor spin over with that?
If thats ok, then Id think the battery or its connections would be next. Does the headlight come on ok? When you press the starter button, does the light go out? Youll need a volt meter, to check voltage...should be over 12.5 at rest, and more than 10 while cranking.
Old Apr 25, 2004 | 08:08 PM
Rhames's Avatar
After a few more attempts, it started. Checked the spark plug and it's fine. I have a feeling the carb may be a bit clogged. When I got it running, I took it out and opened it up and had a slight delay it the acceleration vs. the trottle. Gonna check the carb this week though. Thanks for the input, I appreciate it.
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
hondarider1234
Jul 21, 2015 11:53 PM
