clutch springs
Old Apr 28, 2004 | 01:17 AM
o4ScramblerKing's Avatar
Default clutch springs
i plan on buying the hpd powermaxx exhaust i have a o4 scrambler 500 4x4. my question is which clucth springs should i get.i mostly do trial riding and racing. i really dont wont to buy a clutch kit yet. thanks
Old Apr 28, 2004 | 12:54 PM
fishslab's Avatar
On a four stroke you can get away without a clutch kit. They aren't set up to match the pipe.
Old Apr 28, 2004 | 06:58 PM
ftwflh's Avatar
Try putting in a white or green Polaris primary spring and run you secondary at 2-2.You will notice an improvment.
Old Apr 29, 2004 | 01:02 AM
BigBadScrambler's Avatar
The aggressive clutch kit that I have for that pipe has a HPD brown primary spring, violet secondary spring set on 2-2, 10-58g weights, and a helix that Im not sure of.
Old Apr 29, 2004 | 03:28 AM
scrambler123's Avatar
BBS thats the same setup that comes in a 400 aggressive kit except for the primary. If they use the same helix it would be a 40-36
buddieboy
Dec 9, 2016 05:50 PM
tysonbully
Sep 28, 2015 02:30 AM
jbrewster94
Sep 23, 2015 04:16 PM
roy.hawkins3@gmail.com
Sep 11, 2015 02:35 PM
cdstang
Aug 31, 2015 07:52 AM
