WATER SPASHES SPORTSMAN STOPS RUNNING?
Old Jul 27, 2000 | 03:15 AM
sportsmam's Avatar
WHEN I GO INTO DEEP WATER MY SP STOP RUNNING . IT TAKES A 1 TO 2 MINITES THAN IT STARTS AND RUNS . WHATS THE BEST WAY TO FIX THIS . THANKS DAN 96 SP 500.
Old Jul 27, 2000 | 04:04 AM
Jaime's Avatar
Re water proof your terminal board under the light pod and also the plug cap and coil.
Old Jul 29, 2000 | 11:35 PM
sportsmam's Avatar
Jamie, what is the best way to waterproof the electrical terminals? Thanks.
Old Jul 30, 2000 | 02:46 AM
Jaime's Avatar
Take nygel or dielectric greese and put it on every terminal on the board and on the connectors. plus the coil wire and plug cap also check your grounds they maybe are loose and shorting out with the water.
Old Jul 30, 2000 | 06:29 PM
sportsmam's Avatar
Jamie, where do I buy this type of grease? Where are my grounds located?
Old Jul 30, 2000 | 07:33 PM
Jaime's Avatar
Go to an outo parts store and get it it is exoensive so brace yourself, Get the big tube you will need it.
Old Aug 2, 2000 | 08:38 PM
sportsmam's Avatar
IM GOING THIS WEEKENG AND GETTING SOME.A FRIND IS ON HERE TO NOW JAMIE SAY HI TO MASH MUD.
Old Aug 3, 2000 | 02:32 AM
Jaime's Avatar
Hello mud mash !!!!!!!!!
Old Aug 4, 2000 | 12:32 AM
gregsims's Avatar
Save yourself the hassle. Your problem is in the faulty check valve in your carborater. Plug the drain line before you go into water again and this will not happen. I posted a topic a few months ago.
"Polaris Sportsman Tips" You might want to read it.
Greg
Old Aug 4, 2000 | 12:36 AM
Tim1's Avatar
What year is your bike? Mine used to die when splashed because of it's cheap paper air filter got wet.
