Clutch cover questions...Please help...
Old May 21, 2004 | 10:20 PM
dsdrew's Avatar
Default Clutch cover questions...Please help...
I am trying to put new clutch springs and I cannot remove the cover..All bolts are removed...The foot peg is also removed..i didnt forget the starter bolts or the shifter lever.....the cover is still tight to the motor...Do I have to remove the water pump?? If I pry any harder i feel I am going to break the cover...
Old May 21, 2004 | 10:30 PM
SANDMAN430's Avatar
did you get any movement at all? or is it stuck solid?
Old May 21, 2004 | 10:31 PM
dsdrew's Avatar
No movement at all..It is solid.
Old May 21, 2004 | 10:48 PM
dsdrew's Avatar
Well I am going to go try on it some more I hope it will come off [img]i/expressions/face-icon-small-disgusted.gif[/img]
Old May 21, 2004 | 11:08 PM
lilnotts's Avatar
did you disconect the cable? i'm pretty sure you need to turn that actuator lever to get it off
Old May 22, 2004 | 02:06 AM
dsdrew's Avatar
LiLnoTTs..You are Correct..I took the cable off and turned the lever and it slide right off.
Old May 22, 2004 | 09:05 AM
SANDMAN430's Avatar
glad it was that easy
Old May 22, 2004 | 03:38 PM
lilnotts's Avatar
glad i could help, i knew mine was like that too, and i thought we had to do that to get it off but i wasn't 100% sure
Old May 22, 2004 | 10:17 PM
Entomber's Avatar
Becareful putting it back on, there is a plastic peice where the clutch arm shaft go in. It's plastic, I've heard of guys ruining it. Make sure you take your time and put it in properly.
fordfaithful21
Dec 7, 2015 05:52 PM
GODsRebel
1) Engine problems..
11
Sep 8, 2015 12:07 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
toonces
Sep 5, 2015 01:14 PM
cdstang
Aug 31, 2015 07:52 AM
