starter problems
Old May 22, 2004 | 03:45 PM
thewayout420's Avatar
Default starter problems
hi guys,i need some help..im in the process of putting my scrammy back together,i put the starter back in but now when i turn her over the gear on the starter wont kick out to engage the flywheel,did i do something wrong?
Old May 22, 2004 | 03:48 PM
BigBadScrambler's Avatar
I hate that. My starter drive was doing that. I put some synthetic grease on both ends of the drive gear and any other part that moves on it. It helped out a lot. Sometimes I have to tap on the recoil housing though to get it to kick out. Only when its cold though
Old May 22, 2004 | 04:08 PM
tbsleeper's Avatar
my father just took the starter on his scrammy 400 apart because it wasnt working....and the whole inside was corroded becasue of rust.
Old May 22, 2004 | 05:54 PM
BigNig's Avatar
check the ground on the bottom used to happen to me.
Old May 22, 2004 | 06:00 PM
mariner's Avatar
hey 420 the starter and starter drive are two different things and it sounds like your starter drive is sticky on the recoil side. I took mine apart and cleaned it up and now it works good. there is a little ring on the top you have to pry off. When you put it back together give it a little tap with a hammer because it gets stretched when you take it off. hope this helps
Old May 22, 2004 | 11:25 PM
quadwrench's Avatar
The Dark Side possibility............. Did you happen to disconnect the battery, then maybe connect it back with reverse polarity? This will make the starter spin backwards and the starter drive will never engage.
Old May 23, 2004 | 12:49 AM
Im glad that didnt happen when I by mistake put my battery in backwards. I took my starter drive gear out, cleaned it, regreased it, and was good to go.
Old May 23, 2004 | 06:37 AM
yeah i did disconnect the battery and im 99.9% sure i hooked it up right.
Old May 23, 2004 | 03:30 PM
mariner's Avatar
any luck with your starter
Old May 23, 2004 | 03:43 PM
yeah i took it back apart,greased it up and now it seems to work fine[img]i/expressions/face-icon-small-smile.gif[/img]
skinnyr6
Aug 25, 2023 02:18 AM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
tweeder
Jul 5, 2015 01:57 PM
